crankcase halves
force 150 fl
I wanted to know if I need to have crankcase halves plane each time I rebuild a engine. Jb
Walker
Re: crankcase halves
If you do that the crank bearings won't fit.
force 150 fl
Thank's for the input walker , Can you true or light sand to fix and inperfection in surface ? The force book on the 150 tells you can true the crank halves . I dont know the 1/1?????/ that can be taken off But Johnston Is a big no I gather . Just use sealent only ? JB
Dhadley
What imperfections? Are you talking about the fact that the metal looks like a styrofoam cup? Or the gouges where someone pried on the front half because the tapered pin wouldn't come out?
