What was the history requiring a rebuild? With a V6, the most common crack location, if that is a possibility, is the lifter valley just above the lifters. Other than a head gasket or a cracked head, not many other places to get water in the oil just from running on muffs. I would not expect to get water in the oil from that situation from an exhaust problem unless you had shutdown and the manifold filled up with water...
