Cranking engine longer than 10 seconds
SRC145
What could happen if you crank engine longer than 10 seconds while In water ?
what engine?
generally your starter gets hot.
however cranking for longer than 10 seconds means something is wrong.
tpenfield
Battery gets tired . . .
Starter gets hot . . .
Engine says to itself . . . "you aren't going anywhere" :D
Crew starts thinking . . . "we're doomed" :rolleyes:
My previous boat would tend to loose the fuel system 'prime' if left for a week or 2, so it would take a good 10-15 seconds for the (mechanical) fuel pump to bring fuel back up to the engine.
Why do you ask? Trouble starting the engine :noidea:
SRC145
Hey sorry for the late reply its a 5.0fi Volvo penta, I ended up priming the engine Before starting if that’s even possible with the fuel injected engines but it seemed to work so no problems, was basically just concerned with hydro locking or wearing out any parts
Modern engines start right up if in good condition.-----That is why we have remote starters for vehicles.----Push button start in vehicles.----Cranking more than 10 seconds means something is wrong.-----It will damage the starter too.
muc
"Retired" Association of Marine Technicians...
Onlt times that I have seen excessive cranking hydro lock a motor was when that motor had a waterlift muffler.
SRC145
Thanks, I should mention that was the first time taking it out and Actually starting The engine in a couple weeks. I’ll deffs dig in and see if there’s anything going bad.
