Re: Cranking Outboard Out of Water
Just make sure you have enough water in the trash can and don't
have anything behind it that you don't want to get wet. You need
to submerge the water intake, of course, but know if you move it into
gear, you'll throw water out of the can. Always add more water than you
think you can need and make sure you have enough clearance for the
prop to turn without hitting the sides.
On my 50hp, there's plent of room in a regular, outdoor trash can, for
the prop to turn and I do most of my current work this way. However,
keep an eye on how much water is getting pushed out because you can
empty a can a lot quicker than you think and the next thing you know,
your running your motor without water. As to getting water out.. Best way
to go is after you are finished, have someone lift the motor while you pull
the trash can away, then just push it over. It's a lot quicker to empty
that way.
