Crankshaft issue
Steveng
Due to a failed VRO2 pump number 2 cylinder overheated and scored the cylinder. The cylinder can be bored, but I am now concerned about the crankshaft. It shows a slight blueish color on the rod journals. Is this somethiung that can be corrected (ground or polished), or is the crankshaft now junk?
Thanks to all in afvance, Steve
Chris1956
Re: Crankshaft issue
Steve, a faulty VRO pump will not affect only one cylinder. If the other cylinders are unaffected, suspect the carb is clogged.
Steveng
I just rebuilt the carbs. How can I check if a cylinder is receiving fuel/oil?
