I have been trying to diagnose an ignition/spark problem.
I used a T/S guide at CDI to try to get ideas but have not figured out for sure what the problem is.
The problem started with spark only on the right bank of the motor. I tried to swap the 4 and 2 wire connectors to see if the side swapped and then no fire at all, even after I put it back together.
Today, I go to work on it again and was testing the ignition switch first for voltage going back. It was fine and I found a very weak wire for the lanyard safety switch. After I repaired that, I had fire, and on all 6 cylinders. BUT ! ! ! only when the key was in the starting position with the starter engaged. The motor would actually run just fine, the bendix would drop dowm, but continue to spin until the key switch let off of start and the motor would shut off.
I verified that the keyswitch was operating properly. I am not too familiar with boat ignitions, but apparently the start switched power goes to the power pack and according to my book, it is a yellow-red wire. Looking at the diagrams, it looks like the #2 (purple wire) terminal is the ignition power and it has 12+ volts when the switch is in the on position. I then disconnected the yellow-red wire to see if it would fire and run still, and it did not. After I connected it back up, I had no fire anymore at all.
I am thinking the power pack may be bad actually and is acting up. I do not want to spend $200 and it not be the problem, and knowing I cant return it.
Does anyone else have some clues or info to help me properly diagnose this issue?
thanks in advance,
Mike
thanks in advance,
Mike
