Re: Crazy of Not ?
Back in the 70's, my dad let me paint my car with metalflake in his body shop. I just didn't like that the grill would be the same color. Didn't want to buy the whole amount needed, and I got the same idea about glitter. I sprayed the grill down with a good wet coat of clear. Then I had the glitter in a salt shaker with large holes. Gave the grill a good thourogh coat of gold glitter. Oh boy how it sparkled. However it was just as rough as 36 grit sandpaper. Okay, I said, just spray several coats of clear on it and it will be okay. 20 coats later, it looked like I hadn't put any clear on it. Then I thought of sanding it,,,,,,wrong, as soon as I started sanding it smooth, the gold glitter started turning silver. I ended up washing off the mess and painted it flat black with a gold penstripe around it.
That is my experience with it. You can learn from it, or try it yourself,,,,,,but you'll have the same results.....A mess plus the waste of time. Good Luck
