Crazy temp gauge
clinche
i am faced with an erratic temp gauge...
while cruising temp needle starts flickering from 0 to 175..it could stay stable for 5 mins on 175F and suddenly it freaks out on me..
i have good voltage to the gauge and performed a test on the gauge and it worked fine (jump wire between ground and sender and needle went all the way to the right hand side)..
is the temp sender the culprit? how can i fix this problem?
thanks
clinche
Re: Crazy temp gauge
i need to remove the temp sender so i refered to the user manual. first instruction is to remove coolant from closed cooling system however my engine is raw water cooled (5.7 ltr 2bbl).
Do i have to drain any water or can i just remove the sender from the stat?
Thanks
TowRoper
you can just remove it, but you could get some water coming out but wont be much.
littlebookworm
Just remember NOT to put any sealant on the threads of the sending unit. Otherwise, you will isolate it electrically from the block and will not get a temperature reading. Some mechanics do use a metallic-based sealant, but usually there is no need. Hy
clinche
service manual suggests to apply loctite pipe sealant with teflon to the threads of sender...so this is not needed?
Peter1950
Erratic gauge often means bad ground. Usually at the gauge.
Rocky_Road
Ground at gauge is good. Could it be the ground of the sender to the thermo?
Quite possible...you can try backing it out, and then retorqueing it back in place. And make sure that the wire is clean and tight!
Happy boating!
Ayuh,... Has the T-Stat been changed lately,..??
Was the riveted gasket used,..??
Btw,... It's the Tape that isn't reccommended for sealing,...
Use of sealant Paste Is though....
clinche
yes termo & gasket have been replaced however i have no clue on what type of gasket he used..could this cause a problem?
sorry for the late answer
Ayuh,... The proper gaskets have brass grounding rivets in them....
