Crazy temperatures...
Shadow66
So The weather is supposed to get to 32 degrees tonight and then shoot back up to lows of 40's then 50's from then on. A Freak cold snap for this area. It's starting to **** me off.
I have the Alpha 1 Gen II sterndrive. I ran it yesterday so it is filled with nice cool clean water ...what are my (safe) options for tonight?
Re: Crazy temperatures...
Ayuh,... Drain the motor Block,+ Manifolds,... Then lower the drive....
Shadow66
Hey thank you man. I did drain the water out and I believe I do have a single point drain system (someone tell me if this is the two blue cables connected by a black lever on the top of the engine). Not sure how to work the lever yet, but I just popped the snaps and both drain holes began-a-flowin'.
I called my local Stingray dealer just to check...he said to put a single light in the engine compartment overnight that night. I am outside, in a locked up boatyard far away from electric. I could pull it up to the house that night but it is difficult to do for a few reasons. I just drained all the water, totally easy...messy but easy.
Now does anyone know what that small black handle is between the two blue tubes?
Rocky_Road
You can use it to help push the detached ends to the bottom of your bilge.
I have never needed to use the handle...just grabbed the two hoses, and positioned them lower than the block....
