Creaking monster tower!!!!
bowler
my monster tower creaks when towing but silent otherwise. i've been on other boats that rattle when moving, towing or not. anyone else experience similar problems? all bolts are tight. it's nice to say that this is my only boat issue (if you could even call it that) at the moment (touch wood). it's no biggy but monster say their towers are silent - guaranteed!!!!!
oldjeep
Re: Creaking monster tower!!!!
It's entirely possible that it creaks because your hull is flexing as the leverage shifts from side to side - which in turn would make the tower creak.
The tower in your picture looks like the down arms attach directly to the boat - that type of tower is much more succeptible to flexing the boat than the type which has side bars which tie the front and rear mounts together on each side.
ThreeMileBayWaker
Mine squeaks a little while no weight on it and hitting some choppy water, silent when towing.
WAKEBORDER
My Monster Tower also creaked. I tightened all the large nuts but that didn't help. I finally realized that it was the small allen head bolts that needed tightening. After tightening those, all creaking was eliminated. Let me know if this works for you.
Rinker97
what size back up plates does the monster tower come with?
Monsterman1
Monster Tower backing plates are the same size as the tower base....3 inches long 2 inches wide.
Please give Monster Tower a call 877-778-6937 for Technical Support. We'll work with you to repair or remedy the situation by supplying a replacement part, sending you a replacement product or doing what is necessary to make sure your product is performing as it was designed.
Steve
YeboGogo
I would try inserting fiber washers between the pieces. It should absorb the noise.
bowler
thanks for the suggestions all, i'll try these out and see what happens.
d.
Colliemcc
where did you buy your tower, i'm from Ireland aswell and was thinking of gettin a tower.?
Colm
bowler
hi colm,
the tower was on the boat when i bought it. it was fitted by full circle marine in kesh (as far as i know). ask for a guy called joe hull. (his real name, i promise) there are loads on ebay if you fancy fitting yourself. my friend has fitted 2 towers on 2 boats with no problems. i know another dealer who sells them but he is in coleraine. pm me if you want his number.
d.
Colliemcc
how much in euro do u think i could get one for.
where do u buy your stuff here in Ireland for wakeboarding.
bowler
the monster mt1/mt2 towers are 1000+, monster mte towers are cheaper, 700 ish. other cheaper towers would start around 600/650 euro. to be honest i like to shop around and am a bit of a tight git so buy stuff online to make sure i get the best price, after all, wakeboard gear is expensive stuff! i just bought 2 wakeboard racks from ebay, total bargain at ?160 delivered! that's basicially the price of 1 over here.
d.
Colliemcc
I have only started wakeboarding, the end of last year, so getting more into it now.
I bought a wakeboard last year for 100 euro. some I know bought it in aldi for 250 by mistake thought it was a body board.
So I think its time to buy a new one. Any advice on board or where to buy one.
Colm
bowler
i'll pm you. we're getting well off topic here!
d.
