Re: Cross flow or 60 degree ID
the model # you posted is for a CROSSFLOW motor........ without trying to figure the shape of the hood, if you pull the hood off, you can instantly recognize if the motor is a 60 degree or a 90 degree on the 115 and 90 HP models. If you can see the flywheel itself...then it is NOT a 60 degree looper. the 60 degree loopers have a completely covered flywheel with plastic shrouds that hold the linkage and optical eye and cover the power packs. and it says OIS 2000 on the back plastic cover over top the power packs and coils. the thermostats are very easy to access and remove on the 60 degree loopers, they are at the top of each head . the covers are plastic and have a hex the same size as the spark plugs. don't try to turn them off when its cold out..... the plastic breaks easily bob
