Access to the thermostats on a bubble back cross flow motor is somewhat obstructed to say the least. While I had my power head removed for rebuild I made some modifications to the lower engine cover to allow easier access to this area in the future, see photos. I used rivets to secure the rear portion of the cover which can be easily drilled out for removal and either replaced with new rivets or screws with locking nuts. I would recommend using a silicone sealant to fill the gap created by the cut or you will get a slight whistling sound when operating at WOT. http://picasaweb.google.com/epjman/TstatAccess?authkey=Gv1sRgCMzdzoSs05rOmQE#5569100982620031666
Eric
Eric
