crossed wires
fakeplay
Banned
62 fishing scott 71/2 hp mfg. by McCulloch.
How can you tell if the spark plug wires are hooked up to the wrong cylinders ? or does it matter ?
steelespike
Re: crossed wires
Yes it matters.usually they are marked top or something similar.
With the plugs out ground one plug turn till a piston is near top dead center snap the flywheel by hand through the tdc stroke should get a spark.
you'll have to test both wires to find the match.
On that small motor you should be able to rotate it back and forth through the tdc stroke.
tmcalavy
Re: crossed wires
Most manufacturers put a small band, marked with TOP, around the plug that fires the top cylinder...sometimes they get pulled off, I have found others by simply cleaning the dirty wires.
