phx5kegsman
- Joined
- Apr 10, 2021
- 93
Hello, I have a 1978 Johnson 115hp V4 on my '82 Ranger bass boat. This morning after fishing I decided to fool around a bit. I've spent the last two years restoring this boat & motor and I wanted to see how it handled, top speed, etc. I always run it WOT from one fishing spot to the next, but never for too long and always a straight shot. To the point, I was running it around the lake at WOT (about 5300 rpm) and did some sharp turns and experimented with trim. Ran it hard for maybe 15 minutes and then, coming out of a turn and (still up on plane) back to WOT. The motor lost power and seemed to stall. I have I have an auto/off/manual bildge pump switch on the inst. panel that has a green light for auto and red for manual ( I run it on auto with the green lit up). When the motor stalled the red light on the manual side of the switch lit up and flickered bright then faded. When I pulled the throttle back to neutral the rpm's returned to normal, red light went off, and seemed to go back to normal. I stayed in the lake for about another hour with no problems, although I stopped the "hot rodding", lol. Any thoughts on what happened?
Note: My cranking battery is brand new and my voltmeter showed motor was charging it. Actually, at one point the voltmeter showed it was putting out 17 Volts (is that normal??).
Any help will be greatly appreciated. Thanks!
