Tiderunner18
- Joined
- Feb 24, 2007
- 18
My 88spl engine block goes into the machine shop this week. I know one hole will need to be bored and the other three should only need honing. What overbore pistons are available? I've found .020", .030", and .040" so far. Is .040" as big as you can go on these engines?
Also, the guy at the machine shop is recommending that I bore all four holes to the same size with the claim that the engine will be "out of balance". I really don't see much of a problem with one piston being a little bit larger than the others and I've read posts on this forum about people boring only the holes that need it. Any advise?
Is there any other machine work I should have done to the block or heads while everything is apart?
Thanks!
Thanks!
