Crossflow V4 trim indicator position has changed suddenly- sender or gauge?
Traxion
The trim indicator position on my 95 115 crossflow changed suddenly over the last couple trips out. It was reading normal but suddenly started indicating very low. I looked in my manual today and tried to adjust the sender by loosening the bolts and rotatining. I could not get any adjustment and actually made it worse. Indicator needle is now pretty much pinned as low as it can go. I am assuming this is the trim sending unit causing the issue but want to hear opinions. Thoughts?
Thannks
