Re: crossflow?
Crossflow describes the flow of fuel/air mixture and combustion products in the cylinder, above the piston. In a crossflow the load enters thru ports from one side, gets stopped a little by a cast deflector on top of the piston, and after the combustion the waist leaves thru the other side. On a looper the load enters thru opporsite ports and gets mixed in a loop circulation, after combustion the waist exites thru exhaust port. And your 1984 V4 85 hp is a crossflow. You can tell be the look of the four bypass ports on side of cylinders.
