cableguy1979
- Joined
- Jun 25, 2017
- 121
I have a 1996 Crownline 225 CCR with a 454 Mag. To give a little on the history and clarify Ill make it brief. I bought the boat from a friend as i knew it but it had a bad valve guide i had to replace and had to put a new lower Bravo on the boat which came with the boat. Rebuilt the floor, new carpet and took it to the water. Bought a mercury 14 1/4 x 18p 4 blade cast prop. took it to the lake and tested everything out. Boat seems to be doing fine. Takes off fine, planes and cruises seemingly normal but took it slow. I then decided to buy a stainless prop Laser II 14 1/4 x 25p 3 blade prop. Boat is kinda sluggish taking off unless I use the trim tabs to get it up and it does fine. I decided to test top speed with GPS. 55 mph at 5000 rpm. Put the 18p 4 blade back on 45 mph at 5700 rpm. Boat doesn't feel like i remember. To many RPM's and not enough speed to be gained. The guy I bought it from says the boat does 68 mph on a 21p prop. After all the research I've done the 454 mag with a Bravo in a 22.5ft boat should do around 64 mph. What can cause this to happen? I haven't tried a 21p prop yet but the laser II 25p should be best case top end I would think. If it was the coupler Id expect burning rubber, rpm raising to high, If it was a spun prop hub something very similar with RPM. If something is slipping its doing it evenly enough I cant notice through the full RPM range. He gave me a 24p 4 blade Bravo prop that needed redone and said boat ran 64 mph with cooler and two people with that prop. Can there be anything else causing it to drop 10 mph surely with a 25p 3 blade prop 55 mphs isnt top speed. I know of the same exact boat with a 5.7 that does 52 mph. Ive read similar boats with a standard 454 runs 55 mph with a 21p but ive got almost another 100 hp on those with the 454 Mag. This engine is a rare option in this small of a boat. No wet foam, rear bench and sun deck is out of the boat, No odd noises or smells. Could something in the upper clutch be slipping? I dont expect the motor is a problem since its turning 5700 rpm. The lower unit I put on shouldn't have the gear ratio in it as its in the upper I think and its original to the boat. Any help or test?
