Crud....water in cylinder
geneseo1911
I was winterizing the Cobalt this evening. I pulled all the plugs (all looked really good), and proceeded to crank the engine while spraying the oil into the carb. I then sprayed a little more into each plug hole, when to my horror, I found a little bit of water on the head, under the hole for #7. Sure enough, in the bilge was 2-3 tablespoons, and a few more drops spit out as I turned the engine over.
This engine has not been run since our last outing three or four weeks ago. At that time, it ran perfectly. I'm guessing the 31 year old manifolds/risers have given up. I had them off recently, so I suppose it's possible I didn't get the riser gaskets on properly, but I've been kind of looking for an excuse to pick up some aluminum exhaust manifolds, and I think this may be a good time. I'm looking at this kit: Dana Marine . Is there something better I should be looking at? Is dry joint that much better? I like the idea of saving some weight while getting away from the old log style manifolds.
I suppose I oughta run a compression check before dropping the money. I haven't done so since last spring (145-150), but I have no reason to suspect a crack. Would a cracked head/block still run ok? Would it necessarily show up in a compression check?
Re: Crud....water in cylinder
Looks like the Dana Marine system will work, don't know if your power steering pomp will be an issue with this style. Changed mine out with EMI type and then had to bad and fabricate to make it all fit. I like dry fit manifolds to risers which keep the manifold full of cooling water. Only reason I like it better is every modern boat is using them. There are other manufactures like Gil and Stainless (big bucks), and lower cost like CP and GLM.
You could go less expensive and still have aluminum but I do like chrome and polished aluminum.
Stock Mercury Replacement Aluminum Exhaust Kit - Small Block Chevy - CP Performance
I would do the compression test but a crack in a head would not do very well unless it just happened.
