cruising around, why trim?
peacekeeper6
i was wondering why people trim the outdrive up when cruising?
tommays
Re: cruising around, why trim?
to get the boat at its most efficient running angle which saves a LOT of fuel<br /><br />and many times depending on conditions you can make the boat ride a lot more comofortable LESS pounding ect.<br /><br />tommays
jim dozier
If you always have flat calm water, no wind, and its only you driving, and the load is always the same, and you only drive 1 speed, and the trim is where you want it there is no reason to change it. Me, I see a lot of different water, waves, and wind, my load varies, and so does my speed so my finger is always on the trim buttom and my hand is on the throttle. But my car is a 6-speed so take my opinion for what its worth.
peacekeeper6
well i drive around the intercoastal alot, so will it give me a few more MPH on lower RPMs? or just saves gas?
JB
Both.
peacekeeper6
so when i start to cruise just trim up untill i find a sweet spot? or untill the speed starts to decrease/ RPMs increase?
umblecumbuz
Do you mean trim up (trim out), or trim down (trim in), when cruising?<br /><br />Cruising here means pottering (ie. boat not on plane), as opposed to WOT.
peacekeeper6
i guess trimming out, at cruising and WOT, whats the difference?
Silvertip
Trim out = bow lift = less wetted area = less drag = faster = better economy. <br /><br />Trim in = assists hole shot. Flatter ride in rough water. More drag and less efficient.<br /><br />I'm with JimD. Hand always on throttle and finger on trim button.
willamettejeff
Trimming up when crossing a following wave will prevent an event called broaching where the bow as it crosses the waves, drives into the water, turns the boat very sharply and tries to flip you out. Ended up with whiplash for a week and a half when this happened to me. The link below has some very useful information on the subject.<br /><br /> http://www.clubmarine.com.au/internet/clubmarine.nsf/docs/MG19-2+Technical
peacekeeper6
i took the good ol L drive out today and did the trim feature, worked real well hit about 41 at 5500 RPM thanx guys.
