OK, I've tried to give this a good search, but all I could find is one where there was visible "burn" on the gasket(s). Here's perhaps a new question. I got an outboard for almost no cost. The guy had it stored since 2004 and go the boat from his dad when he passed (2002?). It was fogged and stored. He claimed his dad took good care of his stuff (the boat is a '69 and he re-powered in 1995). It's an Evinrude 60 (1995). I did a compression check and all cylinders were dead on 108 PSI (this without being run for 8 years). The motor is immaculately clean on external surfaces (and the powerhead). As I was going over it in order to work it over this winter, I noticed a little white crust on the head and exhaust cover gaskets. I've seen ones that are burnt and this doesn't look burnt or anything. Just like there is some small amount of seepage. So, as I have a working OB on my boat (was thinking of switching out this winter - my current one is an '83 johnson 60 in great condition - but without power trim/tilt which I would like to have for all the fouls in the Potomac River!).
So, my question is, should I replace the head and exhaust gaskets? Is this seepage a sign of some bigger problem (never noticed this on the 8 different OBs I've owned over the years)? I'm going to try and attach some pictures. I have the camera on macro and the surface looks worse than it is - mostly the paint looks brand new on the entire powerhead.
