chieftaing
- Joined
- May 24, 2015
- 21
I'm new to boat/fiberglass repairing but thanks to the many awesome posts on this forum and elsewhere things have been going well. I'll be posting some project/pictures soon, but hit a situation when doing my first layer of 1.5 oz CSM on the underside of replacement deck and needs some guidance.
I tore a slightly oversized piece of 1.5 oz CSM to fit the replacment deck piece, spread the poly resin + hardner on the (marine) plywood deck and let it set up a little, layed down the CSM, and then went to wet it out (I think thats the term I should use - don't want to sound too confident!). The chip brush I was using started dragging clumps of the mat - not good. Tried the 3/8" fiberglass roller that I had been using with great success on the 1708 I used days before to tab some bulkheads and some stringer repair - but that was worse - dragged fibres everywhere. Ended up using a 6" plastic trowel (from auto store for use with bondo) and dragged the resin around. This was best but still pulled fibres out of the mat into clumps.
So - how do you properly wet out the CSM without pulling it apart?
The two pieces I did came out OK, but not great. Some definite white spots where I guess I didn't saturate it enough. It did cure and the properly done sections look great.
Thanks everyone.
Thanks everyone.
