Cured Alot Of Problems
donny284
First Problem Key Switch. Second Problem ; Disrupter Switch On Shifter. Third Problem ; Carbs. All Fixed Now. However Motor Is Running Good But Needed Thermostats - Someone Had Removed Them ; So Motor Will Not Come To Temp And Idle Down. Have New Thermostats And Cap And Spring ; Do Not Want To Install Them Incorrectly - Does Any One Have Schematic Or Know Exactly How To Install Them? They Are Porcelain With Holes In Small End. Thanks.
SKEETR
Re: Cured Alot Of Problems
The schematic on the brp site shows the tstat installed small end in the head opening. The spring open end to the tstat. o-ring seal for the cap.
donny284
hey skeeter, thanks for info. is there an actual schematic diagram on site i can look at? if so where do i go to get there?
thanks
donny
donny284
skeeter
cured the thermostat installation. now motor is idling at 1700 - 1800 rpm. will not idle down. any answers?
thanks
donny
