Re: curing resin
What kind of temps are you working in...?
If you are in a cold climate you can use any number of items that will provide heat...like halogen lights, space heater, etc...
Just be sure to keep an eye on any heat source you intend to leave on and always provide some form of ventilation...
If you are getting any good sunlight, you can use the free UV light to kick off most any resin a lot faster...
That is of course if you you used the minimum required catalyst...
If you didn't, well it won't kick no matter what...
I'll add that time will cure it eventually and the best way to tell is to wipe the area with acetone...if it becomes sticky/tacky, it still has a way to go...
