Current Bleed on a 3 way circuit???
Limited-Time
Went to change the ballast on a light controlled by 2 switches. With the light switches in the off position I still had enough current passing through to give me a small shock :^:^when I touched the bare wires. This does not seem right to me. Seems if the light is off there should on power to the lines. Am I wrong or do I have a problem???
llfish
Re: Current Bleed on a 3 way circuit???
There should be a hot wire running between the two switches. Is this the wire you are talking about?
Limited-Time
No the wires I am referring to are the hot and neutral supplying the light fixture it's self.
bjcsc
There probably was some current stored in the capacitors of the ballast, esp. if it's an electronic ballast...
Limited-Time
At first I figured that too..............But a test light across the lines indicates the presents of some amount of current.
ZmOz
This is why we have circuit breakers. ;)
levittownnick
If the switches are the "Illuminated" or "Dimmable" type, there is a small current path. If they are the standard 3-way variety, there should be no current path UNLESS the Neutral is crossed with the hot wire.
IF your system has a ground, look for Line voltage from the white wire to ground. There should be none or at worst, no more than 5 volts. Do the same for the hot wire. There should be line voltage with the switch on and none when it is off.
If your system doesn't have a ground conductor or shield (BX) then make these measurements to some other ground (Like the water pipe.).
