stuckinthehole
- Joined
- Aug 13, 2011
- 46
I bought this boat a few years ago and have decided to rebuild it this year. It was a custom made boat that the original owner did not do correctly. Floor has soft spots and the liner was separating from the hull.
I tried getting the entire liner out but cant get it to budge at all so I will be cutting the the top edge of the liner to remove the wood spacer that is waterlogged and expanded.
I am wondering what type of wood you guys would replace in this edge. I plan to refiberglass over the top edge onto the hull to provide a seal from any water getting in and causing the same problem.
Once the top edge around the boat is complete I will cut out and remove the deck. I may have to remove any water logged foam and damaged stringers under the deck. Right now I plan to replace the deck with 3/4" Marine fir covered in fiberglass. I've got alot of work to do on this boat before it hits the water again so I will try to keep this updated when I make progress.
My big question right now is what type of wood to replace along the edge of the boat. I will need 2x4's that I will trim up to fit in the space. I have heard that pressure treated is not a good choice due to moisture content. Right now I am thinking of using Kiln dried Whitewood that is normally used for studs in housing. It will have a low moisture content but will probably absorb alot of epoxy. I am up for any suggestions you may have. Thanks. Again I will try to keep this forum updated with my progress.
