Re: Custom fuel tank
Defiantly not a junkyard tank unless you're on some kind of one-way mission. Though aftermarket off-road racing fuel-cells with anti-slosh baffling might work. These are probably more expensive than having someone fabricate a custom fitted tank.
uh....no they wont....
uscg has very strict rules about marine tanks......the tank has to be certified....if you go boom and someone dies...you get to pay.
the fuel system in a boat is something that you cannot play around with.
even if a bud welded a tank in your back yard.....the tank would need to be sent away to be certified marine.
so adapting non marine to marine is a no-no. same with fuel lines and hoses....you need to use marine.....you cant just take a radiator hose and use it as a fill hose.
people dont realize that in a boat.....the gastank is in an enclosed area......this will trap fuel vapors.
that is why boats have blowers in them...to evacuate the vapors prior to starting the engine
in a car.....the fuel system for the most part, is in the open. so if there is a leak....the fumes can dissapate...as well the drips hit the ground and gass off....this is just not so with a boat.
look at lake union in seattle......every year about 10 or 12 boats go boom due to guys playing with non marine fuel stuff
