I am in the process of removing and replacing the deck, stringers and transom. I would like a to install a ski pylon strong enough to use with a tube. I am considering using a pole mounted to the hull through the deck. Can I glass the base to the hull and stringers? Should I only glass the base to the hull to avoid stringer damage? Should I forget the whole idea?
The boat is a 1985 Capri CC with a 90hp Merc. outboard.
I figure the entire length of the pylon to be about 4' from base of hull to the top.
Any ideas are appreciated. Thanks
CTS
CTS
