Bought a bilge pump for my '61 Larson Sea Lion and am contiplating cutting a hole through the hull as there previously hasn't been a bilge pump in it. It is kind of a scary thought to me as I don't know whether a regular hole saw on a 3/8th drill will go through that fiberglass. I have one drain for a sink and was thinking of putting in a T so I could switch from bilge to sink drain but the thru hull fitting in only 1/2 inch ID and the bilge pump throws a lot of water and has a 3/4th ID outlet. What do you think? Would that work?
