I have an 1986 Evinrude 90HP crossflow that I just changed the thermostats and water pump on, but she still overheats. I'm the original owner - only used in fresh water. I know I should pull the exh. cover and cyl. heads to see what’s up, clean passageways and change the water deflectors. However, I've never done this before and want to lessen the chance of busting bolts.
I know a lot has been written on things you can do, but I figure there must be some tried and true procedures out there. My plan is to first run the engine up to operating temp (without overheating) and record the temps of each cylinder, find out which is hot, and then do compression tests. While block is still warm, it might be a good time to put penetrating oil on all the bolts. Perhaps also strike each bolt with a brass drift to shock and help the oil work its way in? While I'm waiting for the new gaskets I could oil them over several days- perhaps Kroil or PB Blaster. Should I heat them with a torch as well, or only do that on stubborn ones? If so, how hot is safe? Am I being too cautious – I’ve snapped bolts before, but never on an OMC. My Suzuki DT115- well let’s just say that OMC apparently was much more diligent in putting dressings on bolts to prevent corrosion.
Much thanks, Jim
Much thanks, Jim
