cylinder head concern
strat150hp
I have a 1989 Johnson V6 150hp motor that was having an overheating problem. I decided to change the T-Stats and while doing this broke off one of the bolts. To make a long (horribly stupid) story short, I accidently drilled a hole into the top of the cylinder head. The hole is 7/64 and goes through to the piston chamber. My concern is this. If I have the hole professionally plugged do you think it will hold? I'm concern that it might not handle the heat and compression? <br /><br />I appreciate any help.
mikeyzx2
Re: cylinder head concern
I would find a used head on ebay or outboard salvage yard, probably the same or cheaper than get current one fixed, plus you'd feel better
jim dozier
If you can't find a used head have the hole welded up by a cylinder head shop. They weld cylinder heads all the time, it should be no big deal. Have them deck the mating surface and you'll be good to go.
CATransplant
I see you posted this a while ago and haven't had an answer. So, you were drilling out the broken bolt and drilled through it and into the combustion chamber, right? Did you get the bolt out after drilling this hole?<br /><br />Here's what I'm thinking. I believe you can probably work out a plug of some kind. It's worth a try. If it fails, a new head will be needed. If it works, you'll save some bucks.<br /><br />What I see happening here is a job that will require tapping the hole...possibly redrilling to enable the right sized tap. Then, using the proper loctite sealant (I don't know which one, frankly, it will be a high-temperature non-removable variety), screwing in a straight allen-headed set screw of the proper size and length to allow reinsertion. of the thermostat cover bolt, with the sealant providing the seal and locking of the setscrew.<br /><br />That done, whatever part protrudes into the combustion chamber will have to be carefully dressed to match the contours of the chamber. High speed air grinder, used by someone who has done such things before.<br /><br />That done, the thing gets reassembled. My guess is that it should hold just fine.<br /><br />An alternative would be to have someone weld the mistaken hole to fill it...using the appropriate filler material. Again grinding to match the combustion chamber. I'm not big on welding aluminum castings, but that's another possibility.<br /><br />Seems worth a try to me, but finding the right person to do the work is the iffy part. They'd have to know their business.<br /><br />You might want to check the price of a replacement head, first, though, through tcoutboard.com or another outboard junkyard. It might not be too bad.
strat150hp
Thank you all for the reply. Yes CATransplant that is how it happened. I also didn't mention I broke four bolts total trying to take the cylinder head cover off, and got a screw extractor stuck in one. I now have the cylinder head off and it is being evaluated by one of our forklifts mechanics ( I work for a material handling company). He has a lot of machenist experience. If he can't repair it I found a used one for 75.00 at http://www.marine-parts-outlet.com/cylinder_heads.htm. It is in Florida so I am kinda worried about the condition, salt water? I will also check out tcoutboard.com. <br />Thanks alot for the replies.
