cylinder head cover 115 merc
fishdan
can any one tell me where i can find a cylinder head cover for a
1984 merc in line 6 - seri # 6526655. my cover has a crack under
the sixth plug, leaking water. did not know it was leaking found it while
working on fireing problem. also what is the tork on the cyclinder cover bolts
thanks
Chris1956
Re: cylinder head cover 115 merc
Dan, Does the water jacket cover really have a crack or does it leak around the bottom spark plug, due to gasket failure? You might try some silicone on the crack, the water pressure is very low....
If not, you might get a water jacket cover at a junk yard or perhaps a dealer. It will be $$.
jimmbo
cover part #1023-8368A1
gasket part # #27-98185
from 1984 parts book, most like the numbers will superceeded.
Torque 85 in-lbs
