Cylinder Head Interchange Help.
Bret L
Hello all. Recently lost power in my 1975 johnson 135hp. Pulled head and found a blown head gasket and a cylinder that had a piece of the top ring break and bounce around. Parts are on order and Im looking for a replacement port side cylinder head. Problem is I cant find an exact match and cannot find a interchange listing. Any help, info, insight would be greatly appreciated. Trying to get back on the lake fishing with my two sons. Thanks in advance, Bret. My head has a casting number of 319942.
Kirkmn
Re: Cylinder Head Interchange Help.
where is the casting number located? is it the serial number on the frost plug?
ezeke
Part number 319942 may be available from sea-way.com and should be matched with the starboard head #319943.
If sea-way does not have one, try the salvage yards for a good used one.
sea-way.com
outboard-parts.com
laingsoutboards.com
tcoutboard.com
fairwindsmarina.com
salvagemarine.com
marinepartsoutlet.com
outboardexchange.com
Superior Marine (800-338-9281)
budgetboats.net
americanoutboard.com
piratemarinesalvage.com
trixieslanding.com
mmmarinesalvage.com
You could use any of the 135 or 140 crossflow heads as long as they are a matched set.
