I'm considering changing the original cylinder heads on my 82 Century, to newer fast burn or a high quench head for more efficency and power. I have looked at the Edelbrock performer heads and intake. I will have to change the exhaust valves, as the stainless valves that come with the heads aren't compatible for marine use. I would also be using Comp cams magnum roller rockers. The heads, intake and rockers will work in the rpm range from idle to 4800 rpm. I want to basically increase efficency, performance and fuel economy. The short block is rebuilt, balanced, blueprinted and clearenced. The cam is stock, and should worrk with the heads and intake. The exhaust is IMCO power riser with through hull only exhaust. The Edelbrock heads are aluminum. Boat will be used in fresh water only. Would Dart or World iron heads be better?
