Re: cylinder leak down test help
1984 Mercruiser 5.7L. I keep finding small amounts of water on the #7 spark plug. . . . I'm doing a leak down test on that cylinder today. I'm not sure when its at top dead center. With the piston all the way up at one point I get 80% leak. I spin the motor over and bring the cylinder back up again and I get 70% leak, so I assume that is the compression stroke. (is that correct?) . . . Please tell me if my logic so far makes sense and any other tips that could help me. Thanks!
Been there done that on a 7.4L . . .
When doing a leak test on a V8, I always start by ID'ing the #1 Cylinder TDC mark on the Harmonic Balancer at the front of the engine. Then I make "Criss-Cross" marks on the balancer with tape or chalk, so that the marks are at 90 degrees of rotation. This gives me a TDC mark for the other cylinders. Then, to test any particular cylinder, it is matter of getting to the #1 Cylinder TDC (plug the #1 spark plug hole with you finger and you will feel the pressure as it is on the compression stroke). Once you are at TDC for #1, it is a matter of rotating the engine 90 degrees for each cylinder down the firing order until you get to #7 (in this case). The marks on the harmonic balancer will keep you in check throughout the rotation sequence.
80% and 70% leak sound high, even for a blown head gasket, so I'd make sure that you are getting TDC on #7 and not BDC. However, if you are getting air bubbles up the cooling system to the thermostat housing, then there is high probability of it being a head gasket.
Other possibilities to keep in mind with a 1984 engine are rust through of the cylinder head or piston sidewall. . . these things are more probable if it has been used in salt water.
I'd come help you, but I am installing a closed cooling system on my 7.4's today . . . and maybe into tomorrow.
Good luck with it. Keep us posted.
