Sureshot
- Joined
- Sep 28, 2011
- 97
I'm hoping someone may be able to help me diagnose the cause of these scratches / scuffs on my cylinder walls. I have a 50 HP Johnson, 2000 model. On the top cylinder, the scratches are on both the left and right side of the cylinder walls. On the bottom cylinder, the scratches are only on the left side. The rest of the walls still have the cross hatching. I noticed the scratches after a trip on the lake where I had a few problems:
1) When I was slowing down to take a break if felt like I lost a cylinder and the engine died. I tried cranking it for almost 30 minutes but couldn't get it to fire. I didn't have my proper tools with me so I couldn't tell if I was getting spark or if I had flooded the engine possibly. I got a tow back to a dock and then tried cranking and the engine fired right up.
2) After I had gotten the engine going again after my 1st problem, we were cruising around 4200 RPM down the lake and then all the sudden the engine just cut out and shut off. It was very quick, not enough time to try pumping the bulb to see if it was starving for fuel. Never got an overheat alarm and my horn had been tested. The engine immediately started back up and I idled it back to the dock. Checked compression when I got home and I was at 120 on both cylinders.
Any idea what likely caused those scratches based on the problems I had? Also, am I ok continuing to run the motor? I took it out one time after I noticed the scuffs and it ran great. Thanks in advance.
