Rancherlee
- Joined
- Jun 6, 2006
- 621
I just got my 88' 88spl last week and the previous owner had it overhauled 2 years ago (1 new piston/sleeve and 3 hone/rering) and he showed me the reciepts. It has about 100 hours on the overhaul and the compression looked good on his gauge (110-120 on all 4). So I bought it and brought it home and installed it on my boat and took it for a spin and it seemed to move my boat pretty good but I was expecting a bit more out of power wise as my old 55hp pushed my boat 31mph and I only got 38mph out of it with this 88spl but the motor seemed to run smooth with a slighly rough idle and I put it back on the trailer and went home to raise it up one more hole. I decided to change the plugs and notice a decent amount of carbon on the pistons/plugs so I checked the compression with my own Mac tools digital compression tester before runing seafoam thru it and the the right bank pistons are down on compression.
#1-97
#2-117
#3-92
#4-119
And after seafoaming
#1-99
#2-117
#3-92
#4-118
SO a borrowed a bore scope from work and I noticed the #1 and #3 (lower compression one) cylinders look very smooth with no scratches or anything and the #2-#4 (good compression ones) I can still see light crosshatching and no scratches. Assuming that all 4 where honed the same what would cause the glazing / accerated wear on the 1-3 cylinders or it is possible that these two cylinders never seated the rings or weren't honed enough? Also this guy lugged the motor pretty good as he got 31-32mph out of it on a 18' cuddy and with the 17 pitch props he gave me with it that only comes out to 4600rpm @ WOT. Is it possible that putting it on my lighter 16' boat and running 5200rpm caused any damage since it was used to running 4600rpm and got carboned up?
#1-97
#2-117
#3-92
#4-119
#1-99
#2-117
#3-92
#4-118
