catalyst-519
- Joined
- Mar 12, 2008
- 64
Rebuilding my first motor. 1964 Evinrude Fisherman 5.5hp Model 5402.
Upon opening the case I noticed a ton of oil in the motor case that had pooled around the base of the powerhead. Brown like car oil.
Tested compression. . . garbage. Removed the cylinder head and the cylinders and plugs are also coated in thick brown oil. Piston heads are also caked with the stuff. It's greasy, not carbon.
Head gasket was cracked btw the two cyls and was bubbled around the cylinder impressions.
Any ideas about what may have happened to this motor before I got my hands on it? Is it even worth fixing or will it likely need boreing?
In addition, how much play is acceptable between the piston and cylinder. There is a tiny wiggle but not massive. Would this indicate a ring job or a complete bore.
Any help would be awesome before I sink any bucks into a lemon.
Cheers---Adam
Cheers---Adam
