D3 110hp Volvo Penta Starter wireing problem 2012 model.
Ozdownunder
I have the following D3 110hp Volvo Penta Starter 2012 model.
I have pulled off starter and replaced fallen off nuts, I cat remember which way the wires go.
Obviously the large nut at top of solenoid takes the battery power cable (Large)
There are three wires two Red (one slightly larger than the other) and a yellow with red stripe.
If I put the two red cables to the larger nut on solinoid the system energizes priming fuel pumps and then stops, my question is do these two red wire go to the larger nut on the solineoid as they both have a large enough eye to fit and the yellow & Red strip is a smaller eye
Thanks in advance for your help
Yellow/Red goes on the post closest small terminal to the engine block. The solid red goes to the large starter post.
