pscrabber59
- Joined
- Apr 12, 2010
- 246
You call that prop damage. This is the result of my first encounter with a boulder.....Had a mishap on the water with the rocks and caused this damage to the propeller. My question is can i still use it or will i have to buy a new one? I have a 2005 Yamaha F25hp Two out of the three blades are damaged
Thanks
You call that prop damage. This is the result of my first encounter with a boulder.....![]()
I would not go WOT with that prop.
I don't where you live. but I could have that prop repaired within 2 days in MICHIGAN.
the reason not to go WOT is that the RPM's will be High, causing damage to the head. My .02
Boattime your right about the low-price props here on i-boats but i'm thinking of waiting till this season is over before buying new so instead of bringing to prop shop i have a bench grinder and did this.
I know its far from being perfect but i think it will hold up for the rest of the season.
btw boattime i was stationed at Subic Bay in the late 70's and some of my navy buddies had a "good time" catching those crabs!! I stayed on the base alot (hehe)
Thanks
