Damaged trim switch on throttle
matth121
is there anyway it can be replaced or would the whole throttle handle need to be replaced. the switch is no longer there, someone removed it because the trim up wasn't working, it was the up solenoid, i wired in a toggle switch to serve the same function but would like to replace the switch if possible. its a 3 position switch, up, down and no contact in center if that makes sense.
stonyloam
Probably can get one, need to know what control. See if you can find it here, and then do a internet search for the part number.
matth121
problem is i can't find any info on the boat- it's a 19-20ft "sunrise 2100" built in 94. it's not a yacht as all google searches for sunrise boats point to, bowrider with 4.3 alpha 1 gen 2 drive. maybe that info doesnt matter. I'll see what i can find
matth121
thanks, looked at a few so far but none seem to match- guess i'll need a few pics of it and maybe i can find a model# or something next time im out. i can give a vague description if that helps- it's a side mount single lever with a red neutral lock that must be squeezed on the handle to shift, it has a square trailer button middle of the shaft and a throttle only switch(round) in the center of the round base/pivot point.
