Dame it i can not stop this lower carb from driping
mcgill
Hello
:confused:my yamaha 150 pro-v drips gas from low carb when i trim it up ,,,,,, is this norm,then when i trim it down it stops. I changed the flot needes still it drips i tested the flows in water no bobbls and thy flot..:mad:
99yam40
Re: Dame it i can not stop this lower carb from driping
Not adjusted correctly is my thoughts.
float Level too high and when you tilt motor fuel comes out the vent
pscrabber59
I concurr with 99Yam sounds like the float level needs adjustment. Had the same problems on smaller motors and it was always the float level.
mcgill
Thank you very much ,,,,,,,,,,,,,,,that sounds right but how did it change after i cleand italso how to ajust?
mcgill
Thank you very much ,,,,,,,,,,,,,,,that sounds right but how did it change after i cleand it?
