enginepower
- Joined
- Jul 5, 2014
- 260
I think I've found my problem but not sure. I have replaced 2 switch boxes already on this 1995 90hp 3cyl. While at idle on the muffs and checking the coil input voltage with DVA, my digital volt meter will sometimes freak out with segments all over the place or shut off only when it's hooked to the #1 cylinder. Other 2 cylinders are reading about 180V. I am suspecting the ignition coil must be feeding back voltage on the control circuit. The first switch box that failed, lost #1 all together but other two were still firing fine. The second time it went out, the whole thing just crapped out. I now have a brand new OEM replacement and it's still doing this weird thing at idle. Will idle fine for a second or two then get real rough and sounds like drive shaft rattling when it does this. Then clear up and do it again but no problems on top end. Am I right by thinking the #1 coil should be replaced?
