Data on Vintage Boat
Skipb48
I'm trying to find information on a boat that is in Pennsylvania while at this time I'm in Michigan, so I can't actually go to see the boat. This is the HIN numbers etc for the boat - OMCS6683B898 Fishing Machine 1665CX. I need to find out the all specs for this boat, especially the beam and the free board. Does anybody know where I can get that information?
Chris1956
KBB usually has some of the info you want on boats. You probably need to determine the brand name, as I think you will need that to look it up.
there is also the fiberglassics library.
briangcc
No disrespect but quickest way to get that info is have the owner walk out with a tape measure and report back to you. Take all of 2 minutes at most.
matt167
It’s a 1988 Lowe 1665 per the HIN. They will have all the information most likely. According to factory specifications
roscoe
Hin decoder says 1998, not '88. model FM166SC
Lowe was part of OMC when they went bancrupt, and has changed ownership several times, and I believe there were actually 3 different "Lowe" companies over the years.
Good luck finding any detailed specs on the boat.
their model numbers are crazy, i believe they marketed the same boat under several different brand names.
Do as brian said above.
matt167
I meant to say 1998. Typo
