frisbee3557
- Joined
- Jun 1, 2009
- 2
Hi Folks. Appreciate any help given.
I have a 2001 Bayliner Ciera 2655. Love the boat, but having some electrical issues. When the engine is off and on any battery source (1, 2, or both) an alarm sounds from the cockpit whenever the cabin or navigation lights are turned on. The pitch of the alarm is different depending on what lights (or combination of lights) are turned on. When engine is running, the depth finder continuously turns off and back on and the ship to shore radio will not turn on. Ship to shore radio will turn on when engine is not running, but I get the same alarm as when the lights are turned on. Also, when the engine is off and I turn on the ship to shore or press the horn button, the gauges on the dash jump.
After looking at this and other message boards for about 4 hours today, it appears as though I have an issue with a bad ground connection. If this is the case, where is the best place to start looking? If its not a grounding problem, what else could be the culprit?
Thanks for any help/advice you can give.
Dave
Dave
