De-bond 5200
KnotConnected
So my Larson Cabrio has four upholstery panels in the cockpit that, in addition to looking slick, apparently act as access panels to the throttle cables (on starboard) and the Shorepower inlet and galvanic isolator (on port). My problem is, sometime during the boat's prior life, some asshat used 5200 to adhere these panels in place. They're stuck, I mean Stuck. Stucker than stuck, SUPER stuck. ..they *aint* moving.
So before I take a dremel, saw, die-grinder and sandpaper to these to destroy them and have someone re-fab new ones that I can *properly* mount, does anyone have any ideas on how I might be able to un-stick these originals? Ive read about various products like Antibond and DeBond that may or may not work, but I also want to make sure it won't ef up the gellcoat on the fiberclass or the vinyl upholstry on the panels.
thanks!
bruceb58
Re: De-bond 5200
Might try a multi tool with a thin blade attachment.
dingbat
Re: De-bond 5200
Debond, etc. only works in direct contact with the adhesive. If they applied the adhesive to the middle of the panel, most likely, it's not going to come unglued.
