de restricitng a 4 stroke mariner
stairliftoheaven
good evening (its evening in london)<br /><br />I bought a 11' inflatable with a 13.5hp 4stroke mariner in spain a couple of years ago. The dealer told me that it was really a restricted 17hp but spanish law allows a maximum of 13.5hp due to local licencing laws. Now, i was reading the owners manual and it seems there are 3 models all different HPs but all have the same bore and stroke. When I serviced the engine the following season, I removed restrictor which sits between the carb and manifold; a 1/4" plate with a half moon shape in line with the venturi. The took it out on the water and the boat now jumps onto plane in a fraction of a second. The point of all this is that it now seems to be overrevving although I don't have a rev counter. After reading this gr8 forum, I reckon I need to find a higher pitched prop to keep the WOT revs down. Not sure about this though, any comments?? Also after removing the restrictor, do I need to change the jets in the carb as it may be runnign lea :confused: Any ideas on the subject much appreciated<br />thanks <br />chris
stairliftoheaven
Re: de restricitng a 4 stroke mariner
oh yeah forgot to mention, have experienced what i think is prop ventilation as well since de restricting....
JB
Moving to Mariner Troubles.
BillP
That's great info but you may need to richen the mixture now to prevent lean running. Compare jet sizes with the larger version.
