HI all, first post hoping for some help or tips.
The history
Bought this boat last year from an owner who did the bare minimum of care but had it running well and I enjoyed a solid summer except for the throttle cables disintegrating.
At the end of the season we had a huge thunderstorm and it sunk the boat. I had it hauled out and managed to recover the engine.
I drained the starter motor, let it sit in the heat to dry out, cleaned the carbs and was able to get it running consistently. I ran it for 15 minutes straight to dry out the engine and then added some anti-freeze and fogged the engine and stored it all winter.
The problem
Now I'm getting ready to enjoy the summer and I'm getting zero response from the engine. Turn the key and nothing happens which would tell me it's a wiring issue. I pumped out any possible remaining gas, put fresh gas in, plugs were fresh as I didn't keep the old ones after sinking.
Some considerations ideas/What's been done
I replaced both throttle cables and retrofitted new cables into the controller, this didn't touch the wiring but while I was working on patching the hull I had the remote hanging off the boat for a bit, wondering if this loosened a wire. The cables shift nicely and it's sitting in neutral but obviously can manipulate it from the engine side to sit loosely in the middle.
I've cleaned the battery terminals and cleaned the thick white wire that comes into the starter solenoid, it gets power from the battery so I've eliminated those options.
Somehow the boatshop gave me two different cables, I'm still working on fitting the other one in. For a brief moment I was getting a clicking sound from the engine from a silver cylinder that looks like it connects to the choke. I have not been able to replicate this since yesterday but it gives me the feeling that the ignition on the key-side is probably okay?
Wiring is really not my forte, but so far all the wires look decent and not corroded and I've made a point of cleaning contacts on them. Overall other than a few surface rust spots the engine looks no worse for wear despite being submerged. Which I thought wouldn't be an issue since I got it running.
Any tips, labelled diagrams, anything would be a huge help, I'm completely lost and I'm sure it's extremely obvious what's going on.
The history
The problem
