Merc90HPnewbie
- Joined
- Jul 27, 2003
- 178
Ok it's my first time getting a boat out of winter storage. All I did in the fall was change out the lower unit oil, run the carbs till empty/sprayed storage seal thru air intakes in each carb and then into the spark plug holes in each cyl. Then turned the flywheel to distribute the oil a bit. Oh by the way this is an 85 90 hp mercury straight six outboard.<br /><br />I know I have to get rid of the old gas in the tank- too bad because I don't know what to do with 10 gallons of 2 stroke pre-mix (that would be a few weeks worth of weed whacking, leaf blowing, and chain sawing straight...)<br /><br />I happened to notice a dead channel on the switchbox as well, but I have a replacement to put on. Hopefully it didn't cause too much damage (compression remains about the same on all 6 cyls) so after replacing the switchbox and verifying spark on all 6 cyls, what do I do next to get it ready? Just pump fuel in with the primer bulb and get her running? Is there any concern with all the oil (storage seal)just sitting in the cylinders? Is there a mini-break in period when coming out of storage?<br />Thanks
