Last year I had a battery drain issue but finally figured out that my radio had a scan memory & took battery juice between outings that killed the battery. My remedy
was to instal a couple special switches to make sure it & the fishfinder which also has a memory & sucks juice even when turned off, were completely dead. Mounted them so it was easy to remember: Left-Off (as in "left off the list") and Right-On (as in hippy lingo from years long gone) Also added to my mental checklist - turn off all electricals when done fishing.
So I take my brother salmon fishing last Tues & we did pretty good. When we retrieved the boat, I thought I had everything off but then noticed that the surface temp probe was on. Ok easy fix - hit the two position switch. We go out again on Wed & upon retrieval, the floor curtosity lights were on - Ok easy fix - hit the two position switch. So I go to uncover the boat this morning (Saturday) at 5:00am for the last day of our fishing derby and notice the dashboard light is on. DUH...3 positon switch...center position is Off. :facepalm:
So I get to the launch ahead of big Bro & launch; pump the bulb a couple times; cross my fingers & turn the key. It turned over rather slow but I was really relieved when it fired up. I never would have lived it down if it had died.
Tom B.
(LongLine)
Tom B.
(LongLine)
